Saltar al contenido principal
Motorola C261 Front Speaker Replacement
Qué necesitas
  1. Motorola C261 Front Speaker Replacement, Place Phone: paso 1, imagen 1 de 1
    • Place the phone with the screen facedown on a flat surface.
  2. Motorola C261 Front Speaker Replacement, Latch and Back Cover: paso 2, imagen 1 de 2 Motorola C261 Front Speaker Replacement, Latch and Back Cover: paso 2, imagen 2 de 2
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
  3. Motorola C261 Front Speaker Replacement, Remove Battery: paso 3, imagen 1 de 2 Motorola C261 Front Speaker Replacement, Remove Battery: paso 3, imagen 2 de 2
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
  4. Motorola C261 Front Speaker Replacement, Clips: paso 4, imagen 1 de 2 Motorola C261 Front Speaker Replacement, Clips: paso 4, imagen 2 de 2
    • Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
  5. Motorola C261 Front Speaker Replacement, Button Circuit Board: paso 5, imagen 1 de 2 Motorola C261 Front Speaker Replacement, Button Circuit Board: paso 5, imagen 2 de 2
    • The circuit board for the buttons is now free to be removed and replaced.
  6. Motorola C261 Front Speaker Replacement, Front Speaker: paso 6, imagen 1 de 2 Motorola C261 Front Speaker Replacement, Front Speaker: paso 6, imagen 2 de 2
    • Pry under the display screen, around each edge until it comes loose from the circuit board.
    • You are removing the black plastic piece that holds the button circuit board. The piece has an aluminum frame around it. The two pieces will be removed together and don't need to be separated.
  7. Motorola C261 Front Speaker Replacement, Lifting Framework: paso 7, imagen 1 de 1
    • Gently remove the plastic and metal framework of the phone by picking it up.
  8. Motorola C261 Front Speaker Replacement: paso 8, imagen 1 de 2 Motorola C261 Front Speaker Replacement: paso 8, imagen 2 de 2
    • The front speaker should be contained in the framework that you just removed. Remove the speaker by lifting it out.
    • Use a tool that isn't sharp to poke it out should the first method prove too difficult.
Conclusión
Jason
Miembro Desde 10/23/14
305 Reputación
3 Guías creadas
Equipo
Michigan Tech, Team 1-6, Lauer Fall 2014 Miembro de Michigan Tech, Team 1-6, Lauer Fall 2014
MTU-LAUER-F14S1G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 115
