Saltar al contenido principal
Motorola Buzz ic502 Screen and Speaker Replacement
Qué necesitas
  1. Motorola Buzz ic502 Screen and Speaker Replacement, Battery: paso 1, imagen 1 de 3 Motorola Buzz ic502 Screen and Speaker Replacement, Battery: paso 1, imagen 2 de 3 Motorola Buzz ic502 Screen and Speaker Replacement, Battery: paso 1, imagen 3 de 3
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 Screen and Speaker Replacement: paso 2, imagen 1 de 2 Motorola Buzz ic502 Screen and Speaker Replacement: paso 2, imagen 2 de 2
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 Screen and Speaker Replacement: paso 3, imagen 1 de 3 Motorola Buzz ic502 Screen and Speaker Replacement: paso 3, imagen 2 de 3 Motorola Buzz ic502 Screen and Speaker Replacement: paso 3, imagen 3 de 3
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: paso 4, imagen 1 de 3 Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: paso 4, imagen 2 de 3 Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: paso 4, imagen 3 de 3
    • Remove all six screws
    • The two top screws here
    • The two middle screws here.
    • And the two bottom screws here, they are covered by plastic pieces that first must be removed with the nylon Spudger.
  5. Motorola Buzz ic502 Screen and Speaker Replacement: paso 5, imagen 1 de 3 Motorola Buzz ic502 Screen and Speaker Replacement: paso 5, imagen 2 de 3 Motorola Buzz ic502 Screen and Speaker Replacement: paso 5, imagen 3 de 3
    • then carefully lift the front off the phone.
    • Marked wire will have to be solderd when re-connecting new screen
    • Speakers are connected to the screen here.
Conclusión
To reassemble your device, follow these instructions in reverse order, soldering wire onto new screen.
Austin Quinn
Miembro Desde 10/20/16
401 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 6-6, Martin Fall 2016 Miembro de UMass Dartmouth, Team 6-6, Martin Fall 2016
UMASSD-MARTIN-F16S6G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 92
