Saltar al contenido principal
Motorola Buzz ic502 Keypad Replacement
Qué necesitas
  1. Motorola Buzz ic502 Keypad Replacement, Battery: paso 1, imagen 1 de 3 Motorola Buzz ic502 Keypad Replacement, Battery: paso 1, imagen 2 de 3 Motorola Buzz ic502 Keypad Replacement, Battery: paso 1, imagen 3 de 3
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 Keypad Replacement: paso 2, imagen 1 de 2 Motorola Buzz ic502 Keypad Replacement: paso 2, imagen 2 de 2
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 Keypad Replacement: paso 3, imagen 1 de 3 Motorola Buzz ic502 Keypad Replacement: paso 3, imagen 2 de 3 Motorola Buzz ic502 Keypad Replacement: paso 3, imagen 3 de 3
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 Keypad Replacement, Keypad: paso 4, imagen 1 de 2 Motorola Buzz ic502 Keypad Replacement, Keypad: paso 4, imagen 2 de 2
    • Remove the plastic pieces with metal spudge
    • Under both are two screws, remove those as well.
    • Remove the other four screws on back of phone.
  5. Motorola Buzz ic502 Keypad Replacement: paso 5, imagen 1 de 1
    • Carefully lift screen as to not snap wire that connects it (shown is a version in which the screen has been fully removed).
    • Lift off keypad and replace.
Conclusión
Austin Quinn
Miembro Desde 10/20/16
401 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 6-6, Martin Fall 2016 Miembro de UMass Dartmouth, Team 6-6, Martin Fall 2016
UMASSD-MARTIN-F16S6G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 93
