Saltar al contenido principal
Motorola Atrix HD Rear Chassis Disassembly
Qué necesitas
  1. Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: paso 1, imagen 1 de 3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: paso 1, imagen 2 de 3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: paso 1, imagen 3 de 3
    • Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
    • The adhesive strips may stay on the back cover or the battery.
  2. Motorola Atrix HD Rear Chassis Disassembly: paso 2, imagen 1 de 2 Motorola Atrix HD Rear Chassis Disassembly: paso 2, imagen 2 de 2
    • The back case portion may be removed after the battery has been removed.
    • Use the T5 Torx screwdriver to remove the 10 coarse-thread 5mm screws
  3. Motorola Atrix HD Rear Chassis Disassembly: paso 3, imagen 1 de 3 Motorola Atrix HD Rear Chassis Disassembly: paso 3, imagen 2 de 3 Motorola Atrix HD Rear Chassis Disassembly: paso 3, imagen 3 de 3
    • Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
    • Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
    • The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
Conclusión
2 personas más completaron esta guía.
Gabriel Agaman
Miembro Desde 10/28/15
597 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-8, Miles Fall 2015 Miembro de UMass Dartmouth, Team 1-8, Miles Fall 2015
UMASSD-MILES-F15S1G8
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 251
