Saltar al contenido principal
Motorola Atrix HD Touchscreen and LCD Replacement
Qué necesitas
  1. Motorola Atrix HD  Touchscreen and LCD Replacement, Battery: paso 1, imagen 1 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement, Battery: paso 1, imagen 2 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement, Battery: paso 1, imagen 3 de 3
    • Before disassembling the phone, remove the SIM card and the MICRO-SD card, if equipped.
    • Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
    • Continue working around the edge of the phone using the plastic opening tool.
    • When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
  2. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 2, imagen 1 de 1
    • The adhesive strips are shown in the orange boxes. Be sure not to use too much force to pull off the back cover, or you may risk snapping the back cover.
  3. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 3, imagen 1 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 3, imagen 2 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the red rubber screw cover with a pair of tweezers
  4. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 4, imagen 1 de 2 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 4, imagen 2 de 2
    • Use the T-5 Torx bit to remove the two silver 3.3 mm screws with integrated washers.
  5. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 5, imagen 1 de 1
    • Lift the battery leads to the upward position. The ribbon cable is very thin, be gentle.
  6. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 6, imagen 1 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 6, imagen 2 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 6, imagen 3 de 3
    • Use the plastic opening tool around the edges to loosen the battery.
    • Once the battery is loose, carefully lift from the bottom edge and remove the battery.
  7. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 7, imagen 1 de 1
    • The battery may now be removed.
  8. Motorola Atrix HD  Touchscreen and LCD Replacement, Rear Chassis: paso 8, imagen 1 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement, Rear Chassis: paso 8, imagen 2 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement, Rear Chassis: paso 8, imagen 3 de 3
    • Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
    • The adhesive strips may stay on the back cover or the battery.
  9. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 9, imagen 1 de 2 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 9, imagen 2 de 2
    • The back case portion may be removed after the battery has been removed.
    • Use the T5 Torx screwdriver to remove the 10 coarse-thread 5mm screws
  10. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 10, imagen 1 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 10, imagen 2 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 10, imagen 3 de 3
    • Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
    • Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
    • The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
  11. Motorola Atrix HD  Touchscreen and LCD Replacement, Touchscreen and LCD display: paso 11, imagen 1 de 2 Motorola Atrix HD  Touchscreen and LCD Replacement, Touchscreen and LCD display: paso 11, imagen 2 de 2
    • Begin by removing the 10 Torx T5 motherboard baseplate screws
    • The back chassis can now be removed.
  12. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 12, imagen 1 de 2 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 12, imagen 2 de 2
    • Remove the 10 Torx T5 screws, that hold the metal frame to the motherboard.
  13. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 13, imagen 1 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 13, imagen 2 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 13, imagen 3 de 3
    • After following the steps to access the motherboard, you are ready to remove the touchscreen and LCD display.
    • Use the plastic opening tool to separate the LCD display from the motherboard.
    • The touchscreen may separate from the LCD, however they are both connected to the motherboard as one unit.
  14. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 14, imagen 1 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 14, imagen 2 de 3 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 14, imagen 3 de 3
    • Remove the ribbon cable from the back of the lcd using the plastic opening tool or spudger.
    • Use care removing the ribbon cables. They are very thin and are broken easily.
  15. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 15, imagen 1 de 2 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 15, imagen 2 de 2
    • Remove the ribbon cable connecting the LCD display to the motherboard, be mindful that the ribbon cable is very thin.
    • With the LCD display removed, remove the ribbon cable connecting the touchscreen to the motherboard
  16. Motorola Atrix HD  Touchscreen and LCD Replacement: paso 16, imagen 1 de 2 Motorola Atrix HD  Touchscreen and LCD Replacement: paso 16, imagen 2 de 2
    • The LCD display and the touchscreen may now be replaced.
Conclusión
4 personas más completaron esta guía.
Gabriel Agaman
Miembro Desde 10/28/15
597 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-8, Miles Fall 2015 Miembro de UMass Dartmouth, Team 1-8, Miles Fall 2015
UMASSD-MILES-F15S1G8
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,017
