Saltar al contenido principal
Motorola Atrix 4G Top Speaker Replacement
Qué necesitas
  1. Motorola Atrix 4G Top Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Pry the back cover off the back of the phone.
  2. Motorola Atrix 4G Top Speaker Replacement: paso 2, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Spudger
    $3.99
    • Insert a spudger into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Top Speaker Replacement, Antenna: paso 3, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement, Antenna: paso 3, imagen 2 de 2
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Use gentle force while unscrewing to avoid stripping the screws.
  4. Motorola Atrix 4G Top Speaker Replacement: paso 4, imagen 1 de 1
    iFixit Opening Tool
    $1.99
  5. Motorola Atrix 4G Top Speaker Replacement: paso 5, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement: paso 5, imagen 2 de 2
    iFixit Opening Tool
    $1.99
    • Gently lift the tabs located at the top of the phone using an opening tool.
    • Gently lift the tab located at the bottom of the phone with the same tool.
    • Use an opening tool, not your fingers, because the plastic tabs are easily broken.
  6. Motorola Atrix 4G Top Speaker Replacement: paso 6, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement: paso 6, imagen 2 de 2
    iFixit Opening Tool
    $1.99
    • Insert an opening tool between the front and back of the case.
    • Slide the tool down the side of the phone.
    • Repeat the same process for the other side.
    • There should be a noticeable gap between the front and back cases. If not, repeat this step.
  7. Motorola Atrix 4G Top Speaker Replacement: paso 7, imagen 1 de 1
    • Carefully lift the back case off the phone.
    • Do not completely separate the back case from the phone. The antenna is connected to both cases.
  8. Motorola Atrix 4G Top Speaker Replacement: paso 8, imagen 1 de 1
    iFixit Opening Tool
    $1.99
    • Slide an opening tool beneath the antenna and lift straight up from the motherboard.
    • Lift straight upwards, not at an angle, to avoid damaging the socket underneath.
  9. Motorola Atrix 4G Top Speaker Replacement: paso 9, imagen 1 de 1
    • Ease the antenna from out of its guide along the side of the phone
    • Remove the back case and the antenna from the phone.
    • The antenna is soldered to the back case. When reassembling, do not pull it with too much force.
  10. Motorola Atrix 4G Top Speaker Replacement, Motherboard: paso 10, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement, Motherboard: paso 10, imagen 2 de 2
    Spudger
    $3.99
    • Insert a spudger between the black plastic and the motherboard.
    • Lift upwards with the spudger to dislodge the board.
    • The motherboard should lift up easily. If the white rubber piece shifts, move it back to its original place.
  11. Motorola Atrix 4G Top Speaker Replacement: paso 11, imagen 1 de 1
    Spudger
    $3.99
    • Disconnect the press connectors using a spudger.
    • If you are unfamiliar with using connectors, consult this guide.
  12. Motorola Atrix 4G Top Speaker Replacement: paso 12, imagen 1 de 1
    Spudger
    $3.99
    • Lift the white latch on the ZIF connector using a spudger.
    • Gently pull the black ribbon down and away from the latch.
  13. Motorola Atrix 4G Top Speaker Replacement: paso 13, imagen 1 de 1
    • There should be five distinct parts of the phone: the back cover, the back case, the front case, the battery, and the motherboard.
  14. Motorola Atrix 4G Top Speaker Replacement, Top Speaker: paso 14, imagen 1 de 1
    • In order to get to the top speaker, first remove the rubber cover located directly over the speaker.
    • The orange adhesive strip needs to be peeled off in order to remove the top speaker. This can be done using fingernails or the spudger tool.
  15. Motorola Atrix 4G Top Speaker Replacement: paso 15, imagen 1 de 1
    • Using the spudger, lift up from under the top speaker and it should slide easily out of place.
    • Be careful when removing top speaker out of its housing because it is still connected to the phone. You must undo the connection indicated with the orange circle before complete removal.
    • To undo the connector lift the black flap up - edge closest to the speaker - then the cable slides out
Conclusión
9 personas más completaron esta guía.
Derek Walker
Miembro Desde 04/19/12
297 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-42, Regan Spring 2012 Miembro de Cal Poly, Team 9-42, Regan Spring 2012
CPSU-REGAN-S12S9G42
Miembros de 6
15 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 5,597
