Saltar al contenido principal
Motorola Atrix 4G Motherboard Replacement
Qué necesitas
  1. Motorola Atrix 4G Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Pry the rear cover from the back of the phone.
  2. Motorola Atrix 4G Motherboard Replacement: paso 2, imagen 1 de 2 Motorola Atrix 4G Motherboard Replacement: paso 2, imagen 2 de 2
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Motherboard Replacement, Antenna: paso 3, imagen 1 de 3 Motorola Atrix 4G Motherboard Replacement, Antenna: paso 3, imagen 2 de 3 Motorola Atrix 4G Motherboard Replacement, Antenna: paso 3, imagen 3 de 3
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
  4. Motorola Atrix 4G Motherboard Replacement: paso 4, imagen 1 de 2 Motorola Atrix 4G Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
  5. Motorola Atrix 4G Motherboard Replacement: paso 5, imagen 1 de 2 Motorola Atrix 4G Motherboard Replacement: paso 5, imagen 2 de 2
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G Motherboard Replacement: paso 6, imagen 1 de 1
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G Motherboard Replacement: paso 7, imagen 1 de 1
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  8. Motorola Atrix 4G Motherboard Replacement: paso 8, imagen 1 de 1
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
  9. Motorola Atrix 4G Motherboard Replacement, Motherboard: paso 9, imagen 1 de 2 Motorola Atrix 4G Motherboard Replacement, Motherboard: paso 9, imagen 2 de 2
    • To remove the motherboard, first dislodge the right side of the motherboard, where the external connections are located, from the rest of the phone.
    • This can be done by placing a spudger in between the two ports on the phone, between the black plastic and motherboard, and prying out.
    • The motherboard should be able to be easily lifted upwards after dislodging it.
    • If the white rubber piece moves, replace it where it came from upon reassembly.
  10. Motorola Atrix 4G Motherboard Replacement: paso 10, imagen 1 de 2 Motorola Atrix 4G Motherboard Replacement: paso 10, imagen 2 de 2
    • First, several connections must be disconnected to completely separate the motherboard from the rest of the phone.
    • The connection highlighted with a red box must be pulled down instead of out.
    • Using the spudger tool, separate the two connections on the motherboard highlighted with orange circles by pulling them out.
    • The black switch on top of this connection acts as a lock. Push it forwards to unlock the connection.
  11. Motorola Atrix 4G Motherboard Replacement: paso 11, imagen 1 de 1
    • After disconnecting the motherboard, there should be five distinct and separate parts of the phone: back cover, back case, front case, battery, and motherboard.
Conclusión
5 personas más completaron esta guía.
Derek Walker
Miembro Desde 04/19/12
297 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-42, Regan Spring 2012 Miembro de Cal Poly, Team 9-42, Regan Spring 2012
CPSU-REGAN-S12S9G42
6 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 17
Todo El Tiempo: 6,461
