Introducción
This process involves removing the battery, outer case, and motherboard. After, the microphone can be removed.
Partes
No se requieren partes.
  1. Hold the phone and pull the back latch down towards the bottom. Remove the back panel by releasing the latch and lifting from the top.
    • Hold the phone and pull the back latch down towards the bottom.
    • Remove the back panel by releasing the latch and lifting from the top.
  2. Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up.
    • Remove the battery by pushing the bottom end towards the top, then lifting up.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver. Once the screws are removed, simply lift the back panel off Once the screws are removed, simply lift the back panel off
    • Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
    • Once the screws are removed, simply lift the back panel off
  5. Remove the motherboard by lifting it up and out. Remove the motherboard by lifting it up and out. Remove the motherboard by lifting it up and out.
    • Remove the motherboard by lifting it up and out.
  6. Use tweezers or fingers to remove the microphone. Note that the keypad does not need to be removed to get to the microphone.
    • Use tweezers or fingers to remove the microphone.
    • Note that the keypad does not need to be removed to get to the microphone.
Conclusión
Megan Elrod
Miembro Desde 15/04/12
7 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 6-21, Amido Spring 2012 Miembro de Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Miembros
14 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 477
