Saltar al contenido principal
Motherboard Replacement
Qué necesitas
  1. Motherboard Replacement, Bottom Cover: paso 1, imagen 1 de 2 Motherboard Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Motherboard Replacement: paso 3, imagen 1 de 2 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Motherboard Replacement, Motherboard Cover: paso 4, imagen 1 de 3 Motherboard Replacement, Motherboard Cover: paso 4, imagen 2 de 3 Motherboard Replacement, Motherboard Cover: paso 4, imagen 3 de 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Motherboard Replacement, Battery: paso 5, imagen 1 de 2 Motherboard Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Motherboard Replacement: paso 6, imagen 1 de 2 Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Motherboard Replacement: paso 7, imagen 1 de 1
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
  8. Motherboard Replacement, Speakers: paso 8, imagen 1 de 2 Motherboard Replacement, Speakers: paso 8, imagen 2 de 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  9. Motherboard Replacement: paso 9, imagen 1 de 2 Motherboard Replacement: paso 9, imagen 2 de 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  10. Motherboard Replacement: paso 10, imagen 1 de 2 Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
  11. Motherboard Replacement, Motherboard: paso 11, imagen 1 de 2 Motherboard Replacement, Motherboard: paso 11, imagen 2 de 2
    • Remove these two 4.5 mm Philips silver screws holding down the motherboard.
    • The motherboard should be able to be lifted right out of the housing.
  12. Motherboard Replacement: paso 12, imagen 1 de 3 Motherboard Replacement: paso 12, imagen 2 de 3 Motherboard Replacement: paso 12, imagen 3 de 3
    • You will finds a ribbon cable connecting the motherboard to the control interface circuit board.
    • Using a spudger or plastic opening tool, lift flap on the ribbon cable ZIF connector.
    • Using a plastic pry tool or fine tip plastic tool to open the clamp.
    • Using the tool, try lifting the clamp up on either location, noted by the blue arrow.
    • The ribbon should pop out, if not you should be able to slide it out from the clamp.
Conclusión
2 personas más completaron esta guía.
Samuel Knapik
Miembro Desde 03/04/16
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 354
