Teardown
Este desmontaje no es una guía de reparación. Para reparar tu Morphy Richards Iron, utiliza nuestros manuales de servicio .
This is the iron we will take apart.
First remove the rear or the iron using the flathead screwdriver.
Next remove the cable bridge bracket.
Next remove the screws from the base. (see arrows for location)
Next remove the screw the hold the top on.
To free the long cable remove from terminal block at rear.
At the front of the iron pull out the buttons for the steam and water.
Next unclip the button holder (red circle) by undoing the screws (black circle)
Next remove the bridge clip from the arrows position.
Next remove the inner button (black circle)
Now remove the centre screw (red arrow)
slide off the cable holder from the cable.
Disassemble the plug
First remove the casing.
Now remove the wires from the pins.
Next remove the pins.
Remove front of the iron by undoing the screw (arrow) by first taking off cover cap.
Next take out round selector, this is simply clipped so can be pulled out with pliers.
Next remove the washer parts at the front of the iron.
Take the tubing off.
Remove the seals for the water pump.
Now take pumps out.
Remove the screw (circled) this will lead to the separation of the base and the top.
Remove the top of the iron to reveal the under parts.
Now remove the rubber seals from the plate.
Take out the screws linking to the stainless steel base.
Remove the terminal block from the wires.
Next take off the black section of the iron.
Now remove the screws from the steel base.
Next remove each individual part ( mostly wiring)
All parts at the end of the process.
con 2 otros colaboradores
Miembro Desde 03/17/10
269 Reputación
1 Guía escrita
Insignias: 0
Elige el tamaño y copia el siguiente código para insertar esta guía como un pequeño widget en tu sitio web o foro.
Ultimas 24 horas: 2
Ultimos 7 días: 43
Ultimos 30 días: 111
Todo El Tiempo: 32,517
