Saltar al contenido principal
Montgomery Ward GEN-39500 Back Cover Replacement
Qué necesitas
  1. Montgomery Ward GEN-39500 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Back Cover Replacement: paso 2, imagen 1 de 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Back Cover Replacement: paso 3, imagen 1 de 2 Montgomery Ward GEN-39500 Back Cover Replacement: paso 3, imagen 2 de 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
Conclusión
Dustin Platt
Miembro Desde 04/01/15
931 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-5, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 91
