Introducción
This guide will provide you instructions for the removal of the subwoofer (rear speaker) from the speaker.
Qué necesitas
Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
After removing grille, you will see the speakers.
Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
Identify the eight screws around the border of the front panel.
Using the TR 10 driver, remove the two 8mm screws.
Using the TR 10 driver, remove the six 12mm screws.
Remove the four 10mm screws that secure the rear speaker with a TR 10 driver.
Remove the rear speaker from the housing.
2 personas más completaron esta guía.
