Saltar al contenido principal
Monster SoundStage S1 Mini Speaker Replacement
Qué necesitas
  1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Monster SoundStage S1 Mini Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
  2. Monster SoundStage S1 Mini Speaker Replacement: paso 2, imagen 1 de 2 Monster SoundStage S1 Mini Speaker Replacement: paso 2, imagen 2 de 2
    • Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
  3. Monster SoundStage S1 Mini Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the black putty from the speaker wires at both ends of the speaker board.
  4. Monster SoundStage S1 Mini Speaker Replacement: paso 4, imagen 1 de 3 Monster SoundStage S1 Mini Speaker Replacement: paso 4, imagen 2 de 3 Monster SoundStage S1 Mini Speaker Replacement: paso 4, imagen 3 de 3
    • Solder the black plastic encasing the red and black wires.
  5. Monster SoundStage S1 Mini Speaker Replacement: paso 5, imagen 1 de 2 Monster SoundStage S1 Mini Speaker Replacement: paso 5, imagen 2 de 2
    • Remove both the black and red wires with pliers
    • Pliers may stick to speaker because it is magnetic.
  6. Monster SoundStage S1 Mini Speaker Replacement: paso 6, imagen 1 de 2 Monster SoundStage S1 Mini Speaker Replacement: paso 6, imagen 2 de 2
    • Tuck wires through the hole where the speaker is located, then gently push the speaker out.
    • The 1.2 cm Torx security screws that stayed in place near the speaker will now fall out.
    • To remove the other speaker repeat steps 3-6
Conclusión
Una persona más ha completado esta guía.
Equipo
CSU Fullerton, Team 2-6, Bruce Fall 2016 Miembro de CSU Fullerton, Team 2-6, Bruce Fall 2016
CSUF-BRUCE-F16S2G6
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 512
