Saltar al contenido principal
Moen Posi-Temp Cartridge Part #1112b Replacement
Qué necesitas
  1. Moen Posi-Temp Cartridge Part #1112b Replacement, Moen Posi-Temp Cartridge Part #1112b: paso 1, imagen 1 de 1
    • Turn the water shutoff valve counter-clockwise to the "off" position.
  2. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 2, imagen 1 de 1
    • Open both the hot and cold taps of a nearby faucet or shower until the water no longer flows.
  3. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 3, imagen 1 de 2 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 3, imagen 2 de 2
    • Turn the handle of the shower valve 180 degrees until it is in the "up" or "on" position.
  4. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 4, imagen 1 de 2 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 4, imagen 2 de 2
    • Unscrew the handle screw with an Allen wrench.
    • Remove the handle.
  5. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 5, imagen 1 de 2 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 5, imagen 2 de 2
    • Remove the handle adaptor screw with a Phillips screwdriver.
    • Remove the handle adaptor simply by pulling it out.
  6. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 6, imagen 1 de 1
    • Pull out the white key/adjustable limit stop.
  7. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 7, imagen 1 de 3 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 7, imagen 2 de 3 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 7, imagen 3 de 3
    • Gently pull out the stop tube.
  8. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 8, imagen 1 de 3 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 8, imagen 2 de 3 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 8, imagen 3 de 3
    • Using the Phillips head screwdriver, remove the two screws located at the top right corner and bottom left corner.
    • Remove the metal plate.
  9. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 9, imagen 1 de 3 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 9, imagen 2 de 3 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 9, imagen 3 de 3
    • Slide the tip of needle-nose pliers under the notch of the retaining clip and pull the clip upwards.
  10. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 10, imagen 1 de 3 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 10, imagen 2 de 3 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 10, imagen 3 de 3
    • Clamp firmly onto the brass tube with a pair of vice grips and gently but firmly pull out the cartridge.
  11. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 11, imagen 1 de 2 Moen Posi-Temp Cartridge Part #1112b Replacement: paso 11, imagen 2 de 2
    • Insert the new Moen Posi-Temp cartridge.
  12. Moen Posi-Temp Cartridge Part #1112b Replacement: paso 12, imagen 1 de 1
    • Insert the new cartridge into the valve assembly.
    • Ensure that the H/C symbols are facing up.
    • Ensure that the notch on the brass tube is also facing up.
Conclusión
John Mendoza
Miembro Desde 09/17/20
205 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 48
Todo El Tiempo: 1,162
