Saltar al contenido principal
Modal Rechargeable Wine Opener Power Button Replacement
Qué necesitas
  1. Modal Rechargeable Wine Opener Power Button Replacement, Modal Rechargeable Wine Opener power button: paso 1, imagen 1 de 1
    • Carefully place the spudger under the black cylindrical ring and pry it off the top.
  2. Modal Rechargeable Wine Opener Power Button Replacement: paso 2, imagen 1 de 1
    • Remove the spring
    • Remove the spring guide as well to obtain clear access to the screws
  3. Modal Rechargeable Wine Opener Power Button Replacement: paso 3, imagen 1 de 3 Modal Rechargeable Wine Opener Power Button Replacement: paso 3, imagen 2 de 3 Modal Rechargeable Wine Opener Power Button Replacement: paso 3, imagen 3 de 3
    • Remove all four 4mm screws with a J1 Screwdriver
    • Remove the clear cylindrical cap
  4. Modal Rechargeable Wine Opener Power Button Replacement: paso 4, imagen 1 de 3 Modal Rechargeable Wine Opener Power Button Replacement: paso 4, imagen 2 de 3 Modal Rechargeable Wine Opener Power Button Replacement: paso 4, imagen 3 de 3
    • Apply pressure to both of the springs on the surface near the corkscrew, releasing the button port.
  5. Modal Rechargeable Wine Opener Power Button Replacement: paso 5, imagen 1 de 3 Modal Rechargeable Wine Opener Power Button Replacement: paso 5, imagen 2 de 3 Modal Rechargeable Wine Opener Power Button Replacement: paso 5, imagen 3 de 3
    • Remove the malfunctioning buttons from the plastic frame.
Conclusión
Lauren Spicher
Miembro Desde 02/15/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 15-4, Remmell Spring 2017 Miembro de USF Tampa, Team 15-4, Remmell Spring 2017
USFT-REMMELL-S17S15G4
4 Miembros
1 Guía escrita
4 comentarios
where do you by the replacement switch?
Stan Okumura - Contestar
are there any posts for fixing the usb charging port?
Cristian Sanabria - Contestar
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
tom.o@mac.com - Contestar
Could be also the battery. I will try to change the battery.
Daniel Siegenthaler -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 50
Todo El Tiempo: 8,722
