Saltar al contenido principal
Modal MD-SPBT01 Speaker Wiring Replacement
Qué necesitas
  1. Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: paso 1, imagen 1 de 2 Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: paso 1, imagen 2 de 2
    • Use the plastic opening tool to pull the metal cover off the top of the speaker.
  2. Modal MD-SPBT01 Speaker Wiring Replacement: paso 2, imagen 1 de 1
    • Remove the four screws that are inside the holes on the top of the speaker.
    • Use a Phillips 00 screwdriver to remove the 10mm screws.
  3. Modal MD-SPBT01 Speaker Wiring Replacement: paso 3, imagen 1 de 1
    • Pull the top piece of the speaker off to allow access to the interior.
  4. Modal MD-SPBT01 Speaker Wiring Replacement: paso 4, imagen 1 de 1
    • Locate the speaker wire connection and remove the wiring.
    • Locate the LED lighting wire and remove that as well.
  5. Modal MD-SPBT01 Speaker Wiring Replacement: paso 5, imagen 1 de 1
    • Once you disconnect the wires, you can remove the speaker.
  6. Modal MD-SPBT01 Speaker Wiring Replacement: paso 6, imagen 1 de 2 Modal MD-SPBT01 Speaker Wiring Replacement: paso 6, imagen 2 de 2
    • Remove the positive and negative connections for the wiring to fully disconnect the wire.
    • Now that you have removed the defective wiring, you can install a new one.
Conclusión
Nathan Hall
Miembro Desde 10/13/15
258 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 496
