Saltar al contenido principal
Modal MD-SPBT01 Metal Speaker Covering Replacement
Qué necesitas
  1. Modal MD-SPBT01 Metal Speaker Covering Replacement, Metal Speaker Covering: paso 1, imagen 1 de 2 Modal MD-SPBT01 Metal Speaker Covering Replacement, Metal Speaker Covering: paso 1, imagen 2 de 2
    • Remove the damaged metal speaker covering using the plastic opening tool.
    • The covering may be damaged that it is already out of its original place. If this is the condition, you may skip this step.
  2. Modal MD-SPBT01 Metal Speaker Covering Replacement: paso 2, imagen 1 de 1
    • Line up the replacement metal covering with the interior square ridge of the speaker.
  3. Modal MD-SPBT01 Metal Speaker Covering Replacement: paso 3, imagen 1 de 1
    • Firmly press the metal cover into the speaker until it is snug.
    • Super glue may be used to keep the cover in its place, although it is not necessary.
Linea de Meta
Una persona más ha completado esta guía.
Caitlyn Higgins
Miembro Desde 10/13/15
134 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 436
