Saltar al contenido principal
Modal MD-SPBT01 LED Light Wiring Replacement
Qué necesitas
  1. Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: paso 1, imagen 1 de 2 Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: paso 1, imagen 2 de 2
    • Use your plastic opening tool to pry the metal speaker cover off.
  2. Modal MD-SPBT01 LED Light Wiring Replacement: paso 2, imagen 1 de 1
    • You can now use the Phillips #00 screwdriver to remove the four screws.
  3. Modal MD-SPBT01 LED Light Wiring Replacement: paso 3, imagen 1 de 1
    • With the screws removed, you can now remove the top piece of the speaker to gain access to the interior.
  4. Modal MD-SPBT01 LED Light Wiring Replacement: paso 4, imagen 1 de 1
    • Locate the LED wire connection and remove it from the mother board.
    • To make replacing the LED wiring easier, remove the speaker wire to fully disconnect the speaker from the mother board.
  5. Modal MD-SPBT01 LED Light Wiring Replacement: paso 5, imagen 1 de 1
    • Now you can remove the wiring from the speaker side of the device.
    • It might take a bit of work to remove the wires because they are glued down on this side.
  6. Modal MD-SPBT01 LED Light Wiring Replacement: paso 6, imagen 1 de 1
    • Now with the LED wiring removed, a new wire can be installed.
Conclusión
Una persona más ha completado esta guía.
Nathan Hall
Miembro Desde 10/13/15
258 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 630
