Introducción
An easy workflow to replace the battery of your TicWatch C2 , by yourself
With a sharp and thin object, press and open the plastic shell, equipped with the charging connectors, upwards. It is attached with glue , to facilitate , it can also be heated. Do not completely remove the shell but lift it because the connector is attached to the mainboard.
Lift the plastic cover and disconnect the charging connector from the mainboard.
Disconnect the other 4 connectors that remain to remove the battery and mainboard block.
Remove mainboard and battery block from display front housing
With a philips screwdriver remove the two screws that hold the mainboard and the battery to the plastic shell.
The battery is held on the mainboard with little glue.Easy to remove
Una persona más ha completado esta guía.
