Introducción
The following entails a detailed list of instructions to properly and safely remove and replace a defective input/output board for a Mitsubishi WD57734 television.
Qué necesitas
Remove the following 8 Phillips #1 screws:
One 22 mm Phillips #1 in the bottom right corner of the back panel.
One 18 mm Phillips #1 in the top middle of the back panel.
Six 18 mm Phillips #1 in the rest of the back panel.
Removing the back panel exposes the input/output board cover plate.
