Saltar al contenido principal
Mitsubishi WD57734 Back Panel Replacement
Qué necesitas
  1. Mitsubishi WD57734 Back Panel Replacement, Lamp: paso 1, imagen 1 de 1
    • Before disassembling your television, be sure it is powered off and unplugged.
    • Remove the single 18 mm Phillips #1 screw on the lamp access panel.
  2. Mitsubishi WD57734 Back Panel Replacement: paso 2, imagen 1 de 1
    • Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
  3. Mitsubishi WD57734 Back Panel Replacement: paso 3, imagen 1 de 1
    • Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
    • These two screws are permanently attached to the lamp housing and cannot be removed completely.
  4. Mitsubishi WD57734 Back Panel Replacement: paso 4, imagen 1 de 1
    • Using the handle, pull the lamp housing straight back out of the television.
    • Do not touch the glass of the lamp with your bare hands. The oil from your fingers can distort the TV image and lead to other issues.
  5. Mitsubishi WD57734 Back Panel Replacement, Back Panel: paso 5, imagen 1 de 2 Mitsubishi WD57734 Back Panel Replacement, Back Panel: paso 5, imagen 2 de 2
    • Remove the following 8 Phillips #1 screws:
    • One 22 mm Phillips #1 in the bottom right corner of the back panel.
    • One 18 mm Phillips #1 in the top middle of the back panel.
    • Six 18 mm Phillips #1 in the rest of the back panel.
  6. Mitsubishi WD57734 Back Panel Replacement: paso 6, imagen 1 de 1
    • Pull the back panel off of the television by gripping the sides and rotating it down.
Conclusión
Herman Chai
Miembro Desde 10/02/12
196 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 18-39, Regan Fall 2012 Miembro de Cal Poly, Team 18-39, Regan Fall 2012
CPSU-REGAN-F12S18G39
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,029
