Saltar al contenido principal
MistAire Humidifier Cap Spring Replacement
Qué necesitas
  1. MistAire Humidifier Cap Spring Replacement, Cap Spring: paso 1, imagen 1 de 2 MistAire Humidifier Cap Spring Replacement, Cap Spring: paso 1, imagen 2 de 2
    • Lift the blue tank off of the base of the humidifier.
    • The two parts are not attached or snapped together, so they should separate easily.
  2. MistAire Humidifier Cap Spring Replacement: paso 2, imagen 1 de 3 MistAire Humidifier Cap Spring Replacement: paso 2, imagen 2 de 3 MistAire Humidifier Cap Spring Replacement: paso 2, imagen 3 de 3
    • Turn the tank upside down.
    • Turn the round cap counterclockwise to completely unscrew it.
  3. MistAire Humidifier Cap Spring Replacement: paso 3, imagen 1 de 2 MistAire Humidifier Cap Spring Replacement: paso 3, imagen 2 de 2
    • There is a white plastic rod that goes through the center of the cap. It has a flat, circular end and a pointed end. The pointed end has a small, blue, silicone ring around it.
    • Push the flat side of the rod until the pointed end protrudes from the other side of the cap.
  4. MistAire Humidifier Cap Spring Replacement: paso 4, imagen 1 de 3 MistAire Humidifier Cap Spring Replacement: paso 4, imagen 2 de 3 MistAire Humidifier Cap Spring Replacement: paso 4, imagen 3 de 3
    • While still pushing on the rod, tug the small, blue, silicone ring completely off of the pointed end.
  5. MistAire Humidifier Cap Spring Replacement: paso 5, imagen 1 de 2 MistAire Humidifier Cap Spring Replacement: paso 5, imagen 2 de 2
    • Once the ring is off, pull the rod and spring out from the center of the cap.
  6. MistAire Humidifier Cap Spring Replacement: paso 6, imagen 1 de 2 MistAire Humidifier Cap Spring Replacement: paso 6, imagen 2 de 2
    • Slide the broken spring off of the rod.
    • The spring should come off easily.
  7. MistAire Humidifier Cap Spring Replacement: paso 7, imagen 1 de 2 MistAire Humidifier Cap Spring Replacement: paso 7, imagen 2 de 2
    • Slide a new 10x6x19mm Tapered Compression Spring around the rod.
    • Ensure the narrower end of the cone-shaped spring goes first.
  8. MistAire Humidifier Cap Spring Replacement: paso 8, imagen 1 de 2 MistAire Humidifier Cap Spring Replacement: paso 8, imagen 2 de 2
    • Pinch the spring gently to secure it around the rod.
    • Push the pointed end of the rod all the way through the center hole of the cap. Hold it there for Step 9.
  9. MistAire Humidifier Cap Spring Replacement: paso 9, imagen 1 de 3 MistAire Humidifier Cap Spring Replacement: paso 9, imagen 2 de 3 MistAire Humidifier Cap Spring Replacement: paso 9, imagen 3 de 3
    • Push the small blue ring back onto the pointed end of the rod.
    • You should hear a snap when it’s secured.
  10. MistAire Humidifier Cap Spring Replacement: paso 10, imagen 1 de 3 MistAire Humidifier Cap Spring Replacement: paso 10, imagen 2 de 3 MistAire Humidifier Cap Spring Replacement: paso 10, imagen 3 de 3
    • Now that you have fixed the spring-loaded cap, screw the cap clockwise back onto the bottom of the tank.
  11. MistAire Humidifier Cap Spring Replacement: paso 11, imagen 1 de 3 MistAire Humidifier Cap Spring Replacement: paso 11, imagen 2 de 3 MistAire Humidifier Cap Spring Replacement: paso 11, imagen 3 de 3
    • Place the tank back onto the humidifier base.
    • You have now successfully replaced the spring in the MistAire Humidifier!
Linea de Meta
Abby
Miembro Desde 01/31/24
193 Reputación
1 Guía escrita
Equipo
UC Davis, Team 1-1, Andersen Winter 2024 Miembro de UC Davis, Team 1-1, Andersen Winter 2024
UCD-ANDERSEN-W24S1G1
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 93
