Saltar al contenido principal
Mission Hammr Bow String and Cables Replacement
  1. Mission Hammr Bow String and Cables Replacement, Strings and Cables: paso 1, imagen 1 de 1
    • Align the arms of the bow press with the limbs of the bow.
    • Ensure the bow press and bow arms are safe to use for this particular bow.
  2. Mission Hammr Bow String and Cables Replacement: paso 2, imagen 1 de 1
    • Slowly compress the bow press until the string has some slack similar to what's shown in the picture.
    • DO NOT press the bow anymore than you have to. This could result in damage to the bow and the bow press.
  3. Mission Hammr Bow String and Cables Replacement: paso 3, imagen 1 de 1
    • Before you remove the string or cables make sure you know where everything goes for replacement. Take a picture if needed.
  4. Mission Hammr Bow String and Cables Replacement: paso 4, imagen 1 de 1
    • Remove the string.
    • This is the easiest piece to put on and take off. Taking this off first will keep it out of the way so you can access the cables a bit more cleanly.
  5. Mission Hammr Bow String and Cables Replacement: paso 5, imagen 1 de 3 Mission Hammr Bow String and Cables Replacement: paso 5, imagen 2 de 3 Mission Hammr Bow String and Cables Replacement: paso 5, imagen 3 de 3
    • Now remove the cables one at a time.
    • After removing an old cable, immediately replace it with a new one. Doing this will make it easier to ensure you are replacing the cables in the correct spots.
    • The place the cable hooks onto the cam is labeled with a C. The string goes where it's imprinted with an S.
  6. Mission Hammr Bow String and Cables Replacement: paso 6, imagen 1 de 1
    • Once both sets of cables are replaced, make sure they are in the correct grooves before continuing.
  7. Mission Hammr Bow String and Cables Replacement: paso 7, imagen 1 de 2 Mission Hammr Bow String and Cables Replacement: paso 7, imagen 2 de 2
    • Replace the string.
  8. Mission Hammr Bow String and Cables Replacement: paso 8, imagen 1 de 1
    • Now with the string on and in the correct groove check through everything once more.
    • With the bow press, slowly tighten the strings and cables until it looks like it did before the replacement.
    • Use your before picture for a comparison to make sure it's correct.
  9. Mission Hammr Bow String and Cables Replacement: paso 9, imagen 1 de 1
    • Now with the pressure back on the bow everything should be ready to go.
    • Double check to make sure the cables align in the tuning holes and the strings and cables have successfully been replaced.
Conclusión
2 personas más completaron esta guía.
Mathew Reed
Miembro Desde 03/23/21
187 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 577
