Saltar al contenido principal
Minolta X-370 Battery Replacement
Qué necesitas
  1. Minolta X-370 Battery Replacement, Minolta X-370 Battery Replacement: paso 1, imagen 1 de 2 Minolta X-370 Battery Replacement, Minolta X-370 Battery Replacement: paso 1, imagen 2 de 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Minolta X-370 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the batteries, making sure to note their proper alignment.
Conclusión
4 personas más completaron esta guía.
Nick
Miembro Desde 04/19/11
525 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-7, Regan Spring 2011 Miembro de Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Miembros
8 Guías creadas
Un comentario
Hi there, i'm a bit stuck, in my 35mm SLR i was taking a shot and the batteries died, leaving the mirror stuck in the up position, i've changed the batteries and the release for the shutter won't click, i can't advance the film lever and so it's a sitting duck at the moment. They're brand new batteries but because the mirror is up i can't even see if the metering works. because i'm half way through a roll of film i don't want to open the back and ruin it so i'm wondering if there's any way to get the shutter to release again or to get the mirror back down, i don't mind loosing a few blank exposures but again i really wouldn't want to ruin the film. Many thanks and i hope you can get back to me,
Cameron
Cameron Tyson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 41
Ultimos 30 días: 180
Todo El Tiempo: 20,670
