Saltar al contenido principal
Minolta QTsi Maxxum View Finder Replacement
Qué necesitas
  1. Minolta QTsi Maxxum View Finder Replacement, View Finder: paso 1, imagen 1 de 1
    • Locate the battery compartment on the bottom panel of camera.
    • Use a small coin to untwist and open the batter compartment door.
    • Twist the coin counterclockwise to unlock the battery compartment door.
  2. Minolta QTsi Maxxum View Finder Replacement: paso 2, imagen 1 de 1
    • Two batteries are located inside the battery compartment
    • Be careful, the batteries inside the compartment are small and easy to lose.
    • Remove the two batteries from inside the battery compartment by individually pulling each out.
  3. Minolta QTsi Maxxum View Finder Replacement: paso 3, imagen 1 de 1
    • When the batteries are removed from the compartment, one screw will be visible in the bottom of the chamber.
    • Unscrew the (1) black Phillips #00 5mm screw from the bottom of the battery chamber.
    • Be careful when unscrewing the screw because it's small and is easy to lose.
  4. Minolta QTsi Maxxum View Finder Replacement: paso 4, imagen 1 de 1
    • Remove the (2) black Phillips #00 5mm screws that lie on either side of the view finder.
    • Be careful because the two screws are small and are easy to lose.
  5. Minolta QTsi Maxxum View Finder Replacement: paso 5, imagen 1 de 1
    • Remove the (1) black Phillips #00 5mm screw from underneath the flash hood.
    • Be careful because the screw is small and is easy to lose.
  6. Minolta QTsi Maxxum View Finder Replacement: paso 6, imagen 1 de 2 Minolta QTsi Maxxum View Finder Replacement: paso 6, imagen 2 de 2
    • Once all screws are removed, the top of the camera should come off easily.
    • Be careful when removing the top, there are wires connected that could be damaged.
  7. Minolta QTsi Maxxum View Finder Replacement: paso 7, imagen 1 de 1
    • The viewfinder will fall when the screws are removed.
    • Remove the (2) black Phillips #00 5mm screws that hold the viewfinder.
    • Be careful because the screws are small and easy to lose.
Conclusión
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 958
