Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Minolta QTsi Maxxum Shutter Button Replacement
Qué necesitas
    1. Minolta QTsi Maxxum Shutter Button Replacement, Shutter Button: paso 1, imagen 1 de 1
      • Locate the battery compartment on the bottom panel of the camera.
      • Open the battery door by using a coin.
      • In the counterclockwise direction, twist the coin in the battery door groove to open it.
      Pregunta a FixBot
      Agregar Comentario
    2. Minolta QTsi Maxxum Shutter Button Replacement: paso 2, imagen 1 de 1
      • Two batteries are located inside the battery chamber.
      • Remove the two batteries from the battery chamber by picking them up.
      Pregunta a FixBot
      Agregar Comentario
    3. Minolta QTsi Maxxum Shutter Button Replacement: paso 3, imagen 1 de 1
      • There is a screw located underneath the batteries in the battery compartment.
      • Unscrew and remove the (1) black Phillips #00 5mm screw from the battery compartment.
      • Ensure good lighting before attempting to remove this screw because it is hard to see inside the compartment.
      Pregunta a FixBot
      Agregar Comentario
    4. Minolta QTsi Maxxum Shutter Button Replacement: paso 4, imagen 1 de 1
      • From underneath the flash assembly, remove the (1) black Phillips #00 5mm screw
      • Be careful because you can lose the screw
      Pregunta a FixBot
      Agregar Comentario
    5. Minolta QTsi Maxxum Shutter Button Replacement: paso 5, imagen 1 de 1
      • The only screws remaining that hold the top panel of the camera in place are located next to the view finder.
      • Remove the (2) black Phillips #00 5mm screws from both sides of the view finder.
      Pregunta a FixBot
      Agregar Comentario
    6. Minolta QTsi Maxxum Shutter Button Replacement: paso 6, imagen 1 de 2 Minolta QTsi Maxxum Shutter Button Replacement: paso 6, imagen 2 de 2
      • The top panel of the camera should now be easy to lift off. If it is not, make sure that all screws and attachments, listed in steps 1-5, have been removed.
      • Once all screws are removed, lift the top panel from the camera.
      • Be careful when removing the top panel because there are wires connected to it.
      Pregunta a FixBot
      Agregar Comentario
    7. Minolta QTsi Maxxum Shutter Button Replacement: paso 7, imagen 1 de 1
      • Use a metal spudger to push the button out of its socket so that you can place a new one in its place.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jordan Ellery
Miembro Desde 10/10/16
388 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 32
Ultimos 30 días: 63
Todo El Tiempo: 1,012
