Saltar al contenido principal
Minolta QTsi Maxxum Lens Replacement
Qué necesitas
  1. Minolta QTsi Maxxum Lens Replacement, Lens: paso 1, imagen 1 de 2 Minolta QTsi Maxxum Lens Replacement, Lens: paso 1, imagen 2 de 2
    • The lens release button is located on the right front side of the camera.
    • Remove the lens from the camera by pushing the lens release button.
  2. Minolta QTsi Maxxum Lens Replacement: paso 2, imagen 1 de 1
    • The detached module has multiple screws that must be removed in order to reach the lens.
    • Once detached, remove the (4) black Phillips #00 5mm screws from the outer rim of the module.
    • Next, remove the (2) remaining black Phillips #00 5mm screws.
  3. Minolta QTsi Maxxum Lens Replacement: paso 3, imagen 1 de 2 Minolta QTsi Maxxum Lens Replacement: paso 3, imagen 2 de 2
    • Once all screws have been removed, take the back piece off of the lens and replace it.
    • This piece should come off easily without using any tools.
    • There is film underneath the last 2 screws that are removed so be careful when taking it out because it could rip.
Conclusión
Jordan Ellery
Miembro Desde 10/10/16
388 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 665
