Saltar al contenido principal
Minolta Maxxum STsi Strap Rings Replacement
Qué necesitas
  1. Minolta Maxxum STsi Strap Rings Replacement, Main Battery: paso 1, imagen 1 de 1
    • Use the edge of a coin to twist open the battery compartment on the bottom of the camera. (Twist counterclockwise)
  2. Minolta Maxxum STsi Strap Rings Replacement: paso 2, imagen 1 de 1
    • When the compartment opens, pull the AA battery out of its slot.
  3. Minolta Maxxum STsi Strap Rings Replacement, Top Cover: paso 3, imagen 1 de 1
    • Remove the black Phillips #00 5mm screw at the bottom of the battery chamber.
    • If it is too dark to see the screw, it may help to use a flashlight.
  4. Minolta Maxxum STsi Strap Rings Replacement: paso 4, imagen 1 de 1
    • Take out two silver Phillips #00 5.0 mm screws on each side of the viewfinder.
  5. Minolta Maxxum STsi Strap Rings Replacement: paso 5, imagen 1 de 1
    • Open the flash and take out the silver Phillips #00 4.0 mm screw underneath it.
  6. Minolta Maxxum STsi Strap Rings Replacement: paso 6, imagen 1 de 1
    • Open the back-cover of the camera using the back-cover release found on the lower right side of the camera.
  7. Minolta Maxxum STsi Strap Rings Replacement: paso 7, imagen 1 de 1
    • Remove the black Phillips #00 4.0 mm screw from the inside top right section of the camera.
  8. Minolta Maxxum STsi Strap Rings Replacement: paso 8, imagen 1 de 1
    • Remove the black Phillips #00 5.0 mm screw from the back of the film compartment.
  9. Minolta Maxxum STsi Strap Rings Replacement: paso 9, imagen 1 de 2 Minolta Maxxum STsi Strap Rings Replacement: paso 9, imagen 2 de 2
    • Remove the seven black Phillips #00 5.0 mm screws from the bottom panel. The bottom panel is now free to come off.
  10. Minolta Maxxum STsi Strap Rings Replacement: paso 10, imagen 1 de 1
    • Take out two black Phillips #00 2.5 mm screws on the right side panel of the camera.
  11. Minolta Maxxum STsi Strap Rings Replacement: paso 11, imagen 1 de 3 Minolta Maxxum STsi Strap Rings Replacement: paso 11, imagen 2 de 3 Minolta Maxxum STsi Strap Rings Replacement: paso 11, imagen 3 de 3
    • Starting beneath the "SPOT" button, use the round side of the metal spudger and firmly pry underneath the grey top panel of the camera. Work your way counterclockwise around the camera prying at different spots until the top panel starts to come loose. Pry all the way around until you reach the "STsi" logo.
    • This prying will not completely release the top cover. It is also necessary to take off the side panel, as explained in the next step.
  12. Minolta Maxxum STsi Strap Rings Replacement: paso 12, imagen 1 de 2 Minolta Maxxum STsi Strap Rings Replacement: paso 12, imagen 2 de 2
    • Be careful when removing the right side panel. There is a plastic component underneath the side panel that will come free. Note the orientation of this plastic component for reassembly because it is connected to the back-cover release switch.
    • Also be gentle when removing the top panel because it is delicate and is connected by wires.
    • Carefully remove the right side panel by grasping it at the bottom and rotating is counter-clockwise. The top panel is now free to snap off.
  13. Minolta Maxxum STsi Strap Rings Replacement, Strap Rings: paso 13, imagen 1 de 1
    • Remove the four black 5.0 mm Phillips #00 screws to remove the strap holders.
Conclusión
Jasper Kahn
Miembro Desde 04/23/15
228 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-12, Amido Spring 2015 Miembro de Cal Poly, Team 14-12, Amido Spring 2015
CPSU-AMIDO-S15S14G12
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 585
