Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Minolta Maxxum QTSI Tripod Mount Replacement
Qué necesitas
    1. Minolta Maxxum QTSI Tripod Mount Replacement, Tripod Mount: paso 1, imagen 1 de 1
      • With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
      • The screws are located on the outer edge of the bottom panel.
      • Be careful when removing the screws from the panel because they are easy to lose.
      Pregunta a FixBot
      Agregar Comentario
    2. Minolta Maxxum QTSI Tripod Mount Replacement: paso 2, imagen 1 de 2 Minolta Maxxum QTSI Tripod Mount Replacement: paso 2, imagen 2 de 2
      • Once all the screws are removed, the panel should easily come off.
      • Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
      • Pull the bottom panel towards you, it should come off easily.
      Pregunta a FixBot
      Agregar Comentario
    3. Minolta Maxxum QTSI Tripod Mount Replacement: paso 3, imagen 1 de 1
      • The tripod socket is visible when the bottom panel is removed.
      • Remove the (3) black Phillips #00 6.25mm screws from the tripod socket.
      • When the screws are removed, the tripod socket is free and can easily be lost.
      Pregunta a FixBot
      Agregar Comentario
    4. Minolta Maxxum QTSI Tripod Mount Replacement: paso 4, imagen 1 de 2 Minolta Maxxum QTSI Tripod Mount Replacement: paso 4, imagen 2 de 2
      Herramienta utilizada en este paso:
      • Use the tweezers to gently remove the tripod socket, and replace it.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Jordan Ellery
Miembro Desde 10/10/16
388 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 38
Todo El Tiempo: 768
