Introducción
The flashbulb and casing are one component located at the top of the camera. A replacement will be the whole component and not each of the parts separately.
Partes
No se requieren partes.
  1. Locate and remove the silver screws on each side of the camera.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    Agregar Comentario
  2. Then, carefully pry apart the front and back outer casing away from the internal components.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
    Agregar Comentario
  3. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
    • Remove 2mm screws connecting the flash housing to the main components of the camera.
    • Use a Philips #00 screwdriver to remove the black 2.0mm (4 instances) screws .
    Agregar Comentario
    • Use the spudger to push the black plastic hooks through the circuit board to release the flash housing.
    • Once the screws have been removed, pull the circuit board away from the body of the camera.
    • Wires will keep it from completely detaching.
    • Pull the housing away from the circuit board.
    Agregar Comentario
Conclusión
To reassemble device, follow steps in reverse order. This will require the reattachment of wires from the camera to the flashbulb casing.
Keith Sechrist
Miembro Desde 11/03/13
22 Reputación
2 Guías creadas
Equipo
Clemson, Team 12-4, Benson Spring 2013 Miembro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 301
