Saltar al contenido principal
Minolta Dimage Xt Flash Capacitor Replacement
Qué necesitas
  1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: paso 1, imagen 1 de 3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: paso 1, imagen 2 de 3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: paso 1, imagen 3 de 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flash Capacitor Replacement: paso 2, imagen 1 de 3 Minolta Dimage Xt Flash Capacitor Replacement: paso 2, imagen 2 de 3 Minolta Dimage Xt Flash Capacitor Replacement: paso 2, imagen 3 de 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: paso 3, imagen 1 de 2 Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: paso 3, imagen 2 de 2
    • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
Conclusión
Una persona más ha completado esta guía.
Qqq
Miembro Desde 03/11/13
19 Reputación
1 Guía escrita
Un comentario
Its a cap not a battery :D
Eigirdas Gedgaudas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 22
Todo El Tiempo: 1,007
