Saltar al contenido principal
Minolta Dimage Xt Capture Button Replacement
Qué necesitas
  1. Minolta Dimage Xt Capture Button Replacement, Casing: paso 1, imagen 1 de 3 Minolta Dimage Xt Capture Button Replacement, Casing: paso 1, imagen 2 de 3 Minolta Dimage Xt Capture Button Replacement, Casing: paso 1, imagen 3 de 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Capture Button Replacement: paso 2, imagen 1 de 3 Minolta Dimage Xt Capture Button Replacement: paso 2, imagen 2 de 3 Minolta Dimage Xt Capture Button Replacement: paso 2, imagen 3 de 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Capture Button Replacement, Capture Button: paso 3, imagen 1 de 1
    • Choosing the front half of the casing, locate the capture button on the top.
    • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
  4. Minolta Dimage Xt Capture Button Replacement: paso 4, imagen 1 de 1
    • The button will spring free. The capture device consists of the plastic button and a small metal spring.
    • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
Conclusión
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
Miembro Desde 03/11/13
28 Reputación
5 Guías creadas
Equipo
Clemson, Team 12-4, Benson Spring 2013 Miembro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 438
