Saltar al contenido principal
Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement
Qué necesitas
  1. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement, Gearcase Insulator: paso 1, imagen 1 de 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement, Gearcase Insulator: paso 1, imagen 2 de 2
    • Pull up on the shoe release lever until it's perpendicular to the gearcase insulator.
  2. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: paso 2, imagen 1 de 1
    • Pull the shoe assembly out from the saw.
  3. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: paso 3, imagen 1 de 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: paso 3, imagen 2 de 2
    • Remove the gearcase insulator by folding over the rubber, dislodging the insulator from the red shift lever, and pulling it off.
    • Using the screwdriver to help lift the rubber over the lever and folding it over may be helpful.
  4. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement, Service Armature: paso 4, imagen 1 de 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement, Service Armature: paso 4, imagen 2 de 2
    • Use a Torx TR20 screwdriver to remove unscrew the four 57.2 mm screws that secure the service field.
  5. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: paso 5, imagen 1 de 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: paso 5, imagen 2 de 2
    • While holding the motor housing, pull out the service armature.
    • Putting your replacement service armature in can be tricky, but remember the spring at the bottom needs to be loaded.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 43
