Saltar al contenido principal
Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement
Qué necesitas
  1. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement, Power Cord: paso 1, imagen 1 de 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement, Power Cord: paso 1, imagen 2 de 2
    • Use a TR20 Torx screwdriver to remove the five 15.9 mm screws that secure the two halves of the handle together.
    • Use a TR20 Torx screwdriver to remove the two 25.4 mm screws near the motor housing.
  2. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: paso 2, imagen 1 de 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: paso 2, imagen 2 de 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: paso 2, imagen 3 de 3
    • Use a TR20 Torx screwdriver to remove the single 15.9 mm screw that secures the trigger mechanism.
    • Gently lift the trigger mechanism from the handle casing and unseat the power cord wires from their slotted position.
  3. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: paso 3, imagen 1 de 1
    • Use light pressure to pull the white and black wires from the trigger mechanism.
  4. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: paso 4, imagen 1 de 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: paso 4, imagen 2 de 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: paso 4, imagen 3 de 3
    • Notice the small windows on the side of the trigger mechanism; this is where the wires attach.
    • Apply pressure to open these windows with a small flathead screwdriver; this is to ensure the wires are securely in place.
    • Insert the white and black wires from the replacement cord in the sockets perpendicular to the windows.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 59
