Introducción
If you need to replace the gearbox on your Milwaukee M18 2606-20 cordless power drill (the drill slips and loses torque to turn anything) see this guide on how to remove it. The gearbox is what controls the speed and torque of the drill. Removing some of the parts could require a bit of strength so keep this in mind.
Qué necesitas
Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
Una persona más ha completado esta guía.
