Saltar al contenido principal
Milwaukee M12 2407-20 Speed Selector Lever Replacement
Qué necesitas
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: paso 2, imagen 1 de 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: paso 3, imagen 1 de 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: paso 3, imagen 2 de 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: paso 3, imagen 3 de 3
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: paso 4, imagen 1 de 1
    • Use a spudger to pry the broken speed selector lever off the assembly.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 1,602
