Saltar al contenido principal
Milwaukee M12 2407-20 Outer Casing Replacement
Qué necesitas
  1. Milwaukee M12 2407-20 Outer Casing Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Outer Casing Replacement: paso 2, imagen 1 de 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 3,264
