Saltar al contenido principal
Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement
Qué necesitas
  1. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement: paso 2, imagen 1 de 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: paso 3, imagen 1 de 3 Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: paso 3, imagen 2 de 3 Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: paso 3, imagen 3 de 3
    • Use both hands to lift and remove the gear case assembly from the shell casing.
    • Set the gear case assembly aside.
  4. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement: paso 4, imagen 1 de 1
    • While holding the shell in one hand, pull the end of the broken forward/reverse shuttle out of the casing.
    • Set the broken forward/reverse shuttle aside.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 27
Todo El Tiempo: 1,799
