Introducción
If the device is not powering on, the most common cause is from the power cord. Wrapping the cord around the device when stored or using the device from a far distance from where it is plugged may cause the cord issue. This impact wrench operates with a connected power cord. In most cases of having a faulty power issue, it can be easily fixed with replacing the cord line.
But a good news is that the power cord is easy to replace and find from any store. This guide will help you to go through the replacement procedures.
Qué necesitas
Flip the device and remove four 18mm screws using the T20 Torx screwdriver.
Remove the four 14mm screws using the same screwdriver.
