Saltar al contenido principal
Milwaukee Impact Wrench 9070-20 Power Cord Replacement
Qué necesitas
  1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: paso 1, imagen 1 de 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: paso 1, imagen 2 de 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: paso 1, imagen 3 de 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using the T20 Torx screwdriver.
    • Remove the four 14mm screws using the same screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: paso 2, imagen 1 de 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: paso 2, imagen 2 de 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: paso 2, imagen 3 de 3
    • Hold the device so the gray part faces directly towards you.
    • Remove the four screws on the sides using the T20 Torx screwdriver.
    • After removing all screws, use a small plastic pry bar to slide the gearbox assembly forward slightly.
  3. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: paso 3, imagen 1 de 2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: paso 3, imagen 2 de 2
    • Gently remove the upper clam shell from the device.
    • Lift a black colored power cord from its mount at the bottom of the device, so it can move freely.
  4. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: paso 4, imagen 1 de 2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: paso 4, imagen 2 de 2
    • Disconnect the brown field winding wire from the white ac power cord wire.
  5. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: paso 5, imagen 1 de 2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: paso 5, imagen 2 de 2
    • Disconnect the black ac power wire from the connector on the bottom of the forward / reverse switch.
    • Remove the AC power cord and replace it with a new one.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 333
