Introducción
If the motor on the tool spins slowly or not at all the motor field winding may need replacement. To ensure that the field winding is problem first ensure that the device is receiving power and that the brushes are in good condition.
Qué necesitas
Flip the device and remove four 18mm screws using a T20 Torx screwdriver.
Remove four 14mm screws using a T20 Torx screwdriver.
Casi Terminas!
Conclusión
