Saltar al contenido principal
Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch
Qué necesitas
  1. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: paso 1, imagen 1 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: paso 1, imagen 2 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: paso 1, imagen 3 de 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 2, imagen 1 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 2, imagen 2 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 2, imagen 3 de 3
    • Remove the four screws on each corner of the gear box assembly using a T20 Torx screwdriver.
    • Use a plastic pry bar slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 3, imagen 1 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 3, imagen 2 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 3, imagen 3 de 3
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The bushes may need to be compressed for easier removal of the motor.
  4. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 4, imagen 1 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 4, imagen 2 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 4, imagen 3 de 3
    • Pull up on the switch to remove it from the plastic mount.
    • There are six wires connected to the back of the switch.
    • Remove the black field wire winding from the switch.
  5. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 5, imagen 1 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 5, imagen 2 de 3 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 5, imagen 3 de 3
    • Remove the blue lower brush wire (top right) from the connector.
    • Remove the black AC power wire from the switch.
    • The wires do not need to be removed in order, but doing so helps to minimize confusion.
  6. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 6, imagen 1 de 2 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: paso 6, imagen 2 de 2
    • Flip the switch vertically.
    • Remove the white upper brush wire from the connector.
    • Reconnect all wires and replace the new switch back into the plastic case mount.
    • Ensure that all wires are clear of the case so that they will not be damaged on reassembly.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 846
