Saltar al contenido principal
Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement
Qué necesitas
  1. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: paso 1, imagen 1 de 1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: paso 2, imagen 1 de 2 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: paso 2, imagen 2 de 2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: paso 3, imagen 1 de 2 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: paso 3, imagen 2 de 2
    • Locate the black forward/reverse button underneath the chuck.
    • Pull the button gently towards you to remove it from the trigger assembly.
  4. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: paso 4, imagen 1 de 1
    • Using replacement part NO. 45-24-D013 (forward/reverse shuttle), follow the steps of this guide in reverse order.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 739
