Introducción
The following repair guide shows how to remove and replace the directional switch in a Milwaukee Hex Impact Driver 2750-20.
Qué necesitas
Remove the five T9 15.5 mm screws.
Remove the single T9 19.5mm screw.
Remove the two T9 37mm screws.
Remove the trigger assembly completely.
Remove the directional switch by lifting upward using a pair of tweezers, clearing the alignment pole on the trigger assembly.
Casi Terminas!
Conclusión
