Saltar al contenido principal
Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement
Qué necesitas
  1. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement: paso 2, imagen 1 de 1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Directional Switch: paso 3, imagen 1 de 3 Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Directional Switch: paso 3, imagen 2 de 3 Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Directional Switch: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the trigger assembly completely.
    • Remove the directional switch by lifting upward using a pair of tweezers, clearing the alignment pole on the trigger assembly.
    • Insert a new directional switch by aligning the hole on the switch with the pole on the trigger.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 944
