Saltar al contenido principal
Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement
Qué necesitas
  1. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: paso 2, imagen 1 de 1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: paso 3, imagen 1 de 3 Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: paso 3, imagen 2 de 3 Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: paso 3, imagen 3 de 3
    • Pulling directly outward, remove the driver head from the motor assembly by picking it up out of the casing.
  4. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: paso 4, imagen 1 de 1
    • Remove the drive shaft assembly from the motor coils.
    • There will be resistance when removing the drive shaft as there is magnetism working against you.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 762
