Saltar al contenido principal
Milwaukee Hex Impact Driver 2750-20 Output Shaft Bearing Replacement
Qué necesitas
  1. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: paso 2, imagen 1 de 1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Output Shaft Bearing: paso 3, imagen 1 de 1
    • Once the interior is open locate the output shaft driver pictured at the left of the screen.
  4. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: paso 4, imagen 1 de 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: paso 4, imagen 2 de 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: paso 4, imagen 3 de 3
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
  5. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: paso 5, imagen 1 de 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: paso 5, imagen 2 de 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the fan and the drive shaft assembly from the motor core assembly.
    • Using a pair of tweezers, remove the retaining ring.
    • Remove the old bearing and reinstall the new retaining clip.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 16
Todo El Tiempo: 604
