Saltar al contenido principal
Milwaukee Hex Impact Driver 2750-20 Driver Head Replacement
Qué necesitas
  1. Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement: paso 2, imagen 1 de 1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Driver Head: paso 3, imagen 1 de 3 Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Driver Head: paso 3, imagen 2 de 3 Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Driver Head: paso 3, imagen 3 de 3
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 583
