Saltar al contenido principal
Milwaukee Hackzall 2625-20 Trigger Replacement
Qué necesitas
  1. Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: paso 1, imagen 1 de 2 Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: paso 1, imagen 2 de 2
    • Use a T9 Torx screwdriver to remove the one 7.0 mm screw.
    • Use a T10 Torx screwdriver to remove the one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight 16.0 mm screws.
    • Remove the casing to reveal the internal components.
  2. Milwaukee Hackzall 2625-20 Trigger Replacement: paso 2, imagen 1 de 1
    • Use a soldering iron to desolder the connections on the back of the trigger assembly.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  3. Milwaukee Hackzall 2625-20 Trigger Replacement: paso 3, imagen 1 de 2 Milwaukee Hackzall 2625-20 Trigger Replacement: paso 3, imagen 2 de 2
    • Remove the rest of the trigger assembly from the case.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 1,749
