Saltar al contenido principal
Milwaukee Hackzall 2625-20 Terminal Block Replacement
Qué necesitas
  1. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: paso 1, imagen 1 de 2 Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: paso 1, imagen 2 de 2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Terminal Block: paso 2, imagen 1 de 1
    • Carefully remove the terminal block from the casing and note that there is a spring set into it.
  3. Milwaukee Hackzall 2625-20 Terminal Block Replacement: paso 3, imagen 1 de 2 Milwaukee Hackzall 2625-20 Terminal Block Replacement: paso 3, imagen 2 de 2
    • Use a soldering iron to melt any existing soldered attachments.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 1,485
